Atmega 16 Project / Dust sensor
Hi all,
I am doing a school electronics project with one atmega16, Lcd 16x2, 2 actuators and a couple of sensors. I am using Bascom-AVR to programme.
I would like to ask if anyone has a code for sharp dust sensor GP2Y1010AU.
http://pt.farnell.com/jsp/Industrial+Co … ku=9707956
Many Thanks :wink:
Have a read of the datasheet http://www.farnell.com/datasheets/62649.pdf
Once you are have all the right connections for the supply and led, it looks like the voltage output is proportional to the density of dust, you will want to look at the ADC function in bascom.
Hi, thanks for your answer. Actually I started to work with that sensor last week. I have tested it without micro and now I’m trying to interface it with the mega16. I have done a simple code, just to see the adc changes on lcd, but it doesn’t work. Im using Adc(1). See the code please. I think it would be better to use a timer with 3rd pin but I don’t know how to do that. Could you help me please.
$crystal = 4000000
$regfile = “m16def.dat”
Config Lcd = 16 * 2
Config Lcdpin = Pin , Db4 = Portd.3 , Db5 = Portd.2 , Db6 = Portd.1 , Db7 = Portd.0 , E = Portd.6 , Rs = Portd.7
Config Adc = Free , Prescaler = Auto
Dim A As Long
Dim B As Long
Dim Total As Long
'Config Portc.5 = Output
Config Portc.6 = Output
Start Adc
Cls
Do
Set Portc.5
Set Portc.6
Waitms 0.24
Reset Portc.5
Reset Portc.6
Waitms 0.24
A = Getadc(1)
B = Getadc(1)
Total = A + B
Total = Total / 2
Home
Lcd “ADC(1):” ; Total ; " "
Loop
End
Thanks again :wink:
Hi, I am trying to use this sharp dust sensor for my project. I would appreciate if you could email me the circuitry to make this work. my email address sonenarayana@sify.com
