Hello I have got a problem . I have an at tiny 85 and I want to upload a programme on it for a relay which gets activated with an ir receiver . On the arduino nano it works fine but when I upload it on the attiny it does not seem to work . Please help me . Thanks
First of all, test a simple code on your Attiny 85 to check whether its working or not. If it’s not working then you are standing at 0 and If it’s working then you need to check the [Arduino Nano Pinout and Attiny 85 Pinout . I have worked on Arduino UNO and they have different Pinouts if you are using the microcontroller alone and not the Arduino board.
