Base/Rover setup with Original RTK Torch and SparkPNT FPM-T
I should note that the above message pertains specifically to the torch. The SparkPNT FPMT v3.3 I can connect to and get to the serial port just fine. It appears to be running lora firmware 3.0.1 If I can get this torch updated that should help greatly. Alas, it isnt nearly as cut and dried.
(attachments)
