All-
I just uploaded a design that has a few components on the backside of the board.
On the application that I use, when you work on the bottom layer, you sort of look down ‘through’ the board at the bottom layer so that you can do the routing.
I just uploaded a design, and got a response from the DRC. The DRC-bot shows the bottom layer just as the application did…as though you are looking ‘through’ the board at the bottom instead of looking at the bottom from the bottom.
I don’t know how the actual PCB machine interprets these files. Does the machine mirror the underside and route correctly, or do I need to mirror the file myself?
The reason I ask is because in the DRC Bot image, the silk, IC Pins, and board characteristics are mirrored.
Do I need to re-upload a mirrored bottomside, or will my uploaded files be correct for the machine?
Top of board:
http://c2.ac-images.myspacecdn.com/imag … 18212d.jpg
Bottom of board:
