Battery Babysitters in Series?
I am using a single battery babysitter to power a Raspberry Pi. Unfortunately the Pi along with some external sensors and devices seems to be drawing too much power. I am experiencing brown outs. I would like to put two battery babysitters in series to increase the voltage and hopefully get around the low voltage brown outs I am experiencing. Is it possible to put two of the battery babysitters in series? The required power needed to drive the Pi successfully would be 5v at 2A. There is a power management HAT between the battery babysitter and the Pi which takes 5-30v and steps down to the required 5v for the Pi.
No, they max @ 6.4v or so…you should try using a mean-well power supply, adding capacitors, or if you’re feeling really froggy you could run 2 stepdowns/fully separate circuits
xtro:
Is the Battery Babysitter can power and charge the battery at the same time when the power source is connected ? I’m looking for a board that will use the battery only if it’s necessary.
Anna5MM:
xtro:
I am using a single battery babysitter to power a Raspberry Pi. Unfortunately the Pi along with some external sensors and devices seems to be drawing too much power. I am experiencing brown outs. I would like to put two battery babysitters in series to increase the voltage and hopefully get around the low voltage brown outs I am experiencing. Is it possible to put two of the battery babysitters in series? The required power needed to drive the Pi successfully would be 5v at 2A. There is a power management HAT between the battery babysitter and the Pi which takes 5-30v and steps down to the required 5v for the Pi. [OneWalmart GTA Portal
[/quote]
[/quote]
I hope this information is work for you.](https://www.gta-portal.com/)
