This may a stupid question, but I can’t find an answer anywhere. Anyway, I’ve grown interested in batteries and I’ve been researching all the different types and their characteristics and whatnot; but I am still a little confused on the basics. Mainly when a battery is discharging and the relation between it voltage and amperage.
When a battery discharges not only does it lose charge (making its amperage go down), but its voltage also drops. So, say the battery is used in some electric circuit, losing charge is fine until it has none left, but electrical circuits run at specific voltages, so once the voltage drops too far wouldn’t the circuit stop working; and does the voltage drop when there still is charge in the battery?
Also, everything I read about charging/discharging batteries always focuses mainly on the voltage level per cell, which leads to another two questions. 1) Why do they focus only on voltage and not amperage? and 2) If you have a battery pack, is there any way to measure the voltage per cell other than taking apart the pack and measuring each cell individually?
Thanks in Advance!
