I’ll be 120 VAC only.
what is the amperage I can run through the contacts?
The website says 10A on NC (Normally Closed) and 20A on NO, but at 220 VAC Is it 2x that for U.S. 120 VAC?
Also, the Spec /Data sheet says 30A for NO and 20A (for NC?), which does not match either of the SF statements.
Can you clarify?
thanks!
Henry
