begginers stupid question
Hi, just received a couple of Easy WEB II boards from sparkfun.
I attached the 12 VDC, LCD displays “EASY WEB ][ by OLIMEX Ltd.” and connected the Ethernet port of the Easy WEB board to my Laptop.
The ethernet connection does nothing and of course I can not communicate with the board.
Pressing Yellow Button lits LED = STATUS and erases LCD display.
Pressing BLACK and/or WHITE buttons activates Relays and GREEN button activates buzzer.
QUESTION
WHAT AM I DOING Wrong ??
Note: I assume the firmware is already loaded on the chips and the ethernet port should be active at 192.168.0.30 but nothing happens …
Cheers.
Nelson.
sounds like typical cable problem
check how your cable should looks like at
http://www.olimex.com/dev/images/cable.gif
Best regards
Tsvetan
