I’d like to insert my own circuit board in place of a TQFP56 IC. So, instead of soldering a TQFP56 part onto the circuit board I want to solder a TQFP56 header and then mount my circuit onto the header.
These parts exist but the form factor is really clunky:
http://www.epboard.com/eproducts/protoadapter3.htm
Are there better sources?
If BatchPCB can make the boards, it may be possible to create a board with the same rectangular area as a TQFP56 IC with a bunch of vias along the sides, threading AWG30 wire through the holes for use as the TQFP56 leads.
Any better ideas? Is this a new product?
/RJ
