BGB203 Bluetooth to Palm Tungsten E2 Link
Hello All,
Currently have the Bluetooth DIP module:
http://www.sparkfun.com/commerce/produc … ts_id=8461
On an embedded board w/ a PIC controller. I can connect to a PC with a BT dongle and send and receive characters. However, when I attempt to connect with the Palm Tungsten it appears that the connection doesn’t ‘persist’ after the module is discovered and authenticated with the PIN.
I’ve noticed that anytime the power is cycled on the embedded module the PC serial terminal application must be relaunched. I assume to re-establish the link.
Using BtSerialPro on the palm I can connect and maintain a link with the old Bluetooth BlueSmirf MODEM. But the new BGB203 will not work. Like I said before, it appears that the connection doesn’t persist with the new module.
Any ideas?
John
