bluesmirf configuration
hello everybody.
I use a bluesmirf gold on WindowsXP which was set up and working fine for my recent projects.I wanted to change some settings to be able to connect over a usb adaptor.Unfortunately I changed some settings so that the bluesmirf connects over bluetooth but does not send anything to hyperterminal and i cannot set it to command mode.
is it possible that i set it to auto-mode and therefore cannot get into command mode?when i connect it to my arduino borad it does what it should and works fine.
does anyone have an idea what is going on and could give me advice to change the settings again?
thank you!!!
pixedmikles
