Impossible to get in Command Mode with BlueSmirf
Tried pretty much everthing here, resetted the device, used different speeds (9600 - 115200), different hardware control settings, using different software… but i can’t access to the command mode with $$$. Why, why,…? if anyone has experience, tips or tricks he can share, please do. Have a dataline here.
Which BT module do you have exactly ? Take care that the Gold and Silver versions have different protocols. I have Bluesmirf Silver and it works with +++ and I think the gold works with $$$
Checkout http://www.sparkfun.com/datasheets/Wire … rGuide.pdf if you also have the silver. Standard is 9600 bd. Also connect cts and rts when not used
