Bluetooth and Software serial
I have a device with an RN-42 bluetooth module in it. It sends out a serial stream of human readable data. I am trying to read this by using a bluesmirf connected to a pro-mini. I am presently trying to relay the bluetooth data thru an FTDI cable to my computer screen to see that I am reading the bluetooth data correctly - I think I am not.
I can read by original device’s bluetooth serial data using coolterm on my mac.
I can send hard coded serial over FTDI from the pro-mini OK.
But when I try to relay the data by:
#include <SoftwareSerial.h>
int txPin = 7;  // software serial transmit pin
int rxPin = 4;  // software serial receive pin
SoftwareSerial bluetoothSerial( rxPin, txPin );  // Rx, Tx
void setup() {
  bluetoothSerial.begin( 115200 );
  Serial.begin(9600);
void loop() {
if(bluetoothSerial.available())
    char received = bluetoothSerial.read();
    Serial.print(received);
   //delay(25);
The FTDI serial on my screen looks like this:
e…{…,…{.a.t.s.r…n{.{…n"…{Wn.r5{{.u{{…t{…i.{.ni.{…a.tu.5t{.u…
Any thoughts on what might be wrong here?
In the BlueSmirf Getting hookup guide:
It says
" // 115200 can be too fast at times for NewSoftSerial to relay the data reliably"
You might try the example code there which just echoes things back and forth.
