MP3Trigger Library is located: https://github.com/sansumbrella/MP3Trig … ino#readme
NewSoftSerial Library is located: http://arduiniana.org/libraries/newsoftserial/
Ledcontrol Lobrary is located: http://www.wayoda.org/arduino/ledcontro … l#Download
#include <MP3Trigger.h>
#include <NewSoftSerial.h>
// TTL BlueTooth module is connected to pins 0 and 1
// MP3Trigger V2 module is connected to pins 2 and 3
NewSoftSerial MP3Trigger(3,2);
#include <LedControl.h>
#undef round
int cA[] = { B00000110,
             B00001001,
             B00001111,
             B00001001,
             B00001001 };
int cB[] = { B00000111,
             B00001001,
             B00000111,
             B00001001,
             B00000111 };
int cC[] = { B00000110,
             B00001001,
             B00000001,
             B00001001,
             B00000110 };
int cD[] = { B0000111,
             B0001001,
             B0001001,
             B0001001,
             B0000111 };
int cE[] = { B00001111,
             B00000001,
             B00000111,
             B00000001,
             B00001111 };
int cF[] = { B00001111,
             B00000001,
             B00000111,
             B00000001,
             B00000001 };
int cG[] = { B00001110,
             B00000001,
             B00001101,
             B00001001,
             B00000110 };
int cH[] = { B00001001,
             B00001001,
             B00001111,
             B00001001,
             B00001001 };
int cI[] = { B00000111,
             B00000010,
             B00000010,
             B00000010,
             B00000111 };
int cJ[] = { B00001000,
             B00001000,
             B00001000,
             B00001001,
             B00000110 };
int cK[] = { B00001001,
             B00000101,
             B00000011,
             B00000101,
             B00001001 };
int cL[] = { B00000001,
             B00000001,
             B00000001,
             B00000001,
             B00001111 };
int cM[] = { B00010001,
             B00011011,
             B00010101,
             B00010001,
             B00010001 };
int cN[] = { B00001001,
             B00001011,
             B00001101,
             B00001001,
             B00001001 };
int cO[] = { B00000110,
             B00001001,
             B00001001,
             B00001001,
             B00000110 };
int cP[] = { B00000111,
             B00001001,
             B00000111,
             B00000001,
             B00000001 };
int cQ[] = { B00000110,
             B00001001,
             B00001101,
             B00001001,
             B00010110 };
int cR[] = { B00000111,
             B00001001,
             B00000111,
             B00000101,
             B00001001 };
int cS[] = { B0,
             B0,
             B0,
             B0,
             B0 };
int cT[] = { B0,
             B0,
             B0,
             B0,
             B0 };
int cU[] = { B0,
             B0,
             B0,
             B0,
             B0 };
int cV[] = { B0,
             B0,
             B0,
             B0,
             B0 };
int cW[] = { B0,
             B0,
             B0,
             B0,
             B0 };
int cX[] = { B0,
             B0,
             B0,
             B0,
             B0 };
int cY[] = { B0,
             B0,
             B0,
             B0,
             B0 };
int cZ[] = { B0,
             B0,
             B0,
             B0,
             B0 };
LedControl lc=LedControl(12,11,10,3); //assumes only the RLD is connected
char text[] = "HELLO";
int pixelPos=27;
int scrollCount=0;
//virtual coords are 5x27; device coords are 3 panels 6x8 each
unsigned long v_grid[5]; //this will give 5x32 bits
void setup()
  for(int dev=0;dev<lc.getDeviceCount();dev++)
    lc.shutdown(dev, false); //take the device out of shutdown (power save) mode
    lc.setIntensity(dev, 2); //intensity is 1-15
    lc.clearDisplay(dev);
void loop()
  //Scroll thru the text message one time, then go to random display
  initGrid();
  if (scrollCount==0)
    scrollingText();
    delay(40);
    return;
  randomDisplay();
  delay(200);
void showGrid()
  //copy from virt coords to device coords
  unsigned char col8=0;
  unsigned char col17=0;
  unsigned char col26=0;
  for (int row=0; row<5; row++)
    lc.setRow(0,row, rev(   v_grid[row] & 255L             )   ); //device 0
    lc.setRow(1,row, rev(  (v_grid[row] & 255L<<9) >> 9    )   ); //device 1
    lc.setRow(2,row, rev(  (v_grid[row] & 255L<<18) >> 18  )   ); //device 2
    if ( (v_grid[row] & 1L<<8) == 1L<<8)   col8 += 128>>row;
    if ( (v_grid[row] & 1L<<17) == 1L<<17) col17 += 128>>row;
    if ( (v_grid[row] & 1L<<26) == 1L<<26) col26 += 128>>row;
  lc.setRow(0, 5, col8);
  lc.setRow(1, 5, col17);
  lc.setRow(2, 5, col26);
unsigned char rev(unsigned char b)
  //reverse bits of a byte
  return (b * 0x0202020202ULL & 0x010884422010ULL) % 1023;
void initGrid()
  for (int row=0; row<6; row++) v_grid[row]=0L;
void drawLetter(char let, int shift)
  int *pLetter;
  switch (let)
    case 'A': pLetter=cA; break;
    case 'B': pLetter=cB; break;
    case 'C': pLetter=cC; break;
    case 'D': pLetter=cD; break;
    case 'E': pLetter=cE; break;
    case 'F': pLetter=cF; break;
    case 'G': pLetter=cG; break;
    case 'H': pLetter=cH; break;
    case 'I': pLetter=cI; break;
    case 'J': pLetter=cJ; break;
    case 'K': pLetter=cK; break;
    case 'L': pLetter=cL; break;
    case 'M': pLetter=cM; break;
    case 'N': pLetter=cN; break;
    case 'O': pLetter=cO; break;
    case 'P': pLetter=cP; break;
    case 'Q': pLetter=cQ; break;
    case 'R': pLetter=cR; break;
    case 'S': pLetter=cS; break;
    case 'T': pLetter=cT; break;
    case 'U': pLetter=cU; break;
    case 'V': pLetter=cV; break;
    case 'W': pLetter=cW; break;
    case 'X': pLetter=cX; break;
    case 'Y': pLetter=cY; break;
    case 'Z': pLetter=cZ; break;
    default:return;
  //loop thru rows of the letter
  for (int i=0; i<5; i++)
    if (shift>0) //positive shift means letter is slid to the right on the display
      v_grid[i] += (long)pLetter[i] << shift;
    else //negative shift means letter is slid to the left so that only part of it is visible
      v_grid[i] += (long)pLetter[i] >> -shift;
void scrollingText()
  for (int i=0; i<strlen(text); i++)
    drawLetter(text[i], i*5 + pixelPos);
  pixelPos--;
  if (pixelPos < -5*(int)strlen(text))
    pixelPos=27;
    scrollCount++;
  showGrid();
void randomDisplay()
  for (int device=0; device<3; device++)
      lc.setRow(device,row,random(0,256));
