Bluetooth communication b/w two edison
I have two edison’s, one running on the arduino breakout board and the other on the mini breakout board. After burning the code on the edison attached to the mini, i am planning to connect it to a battery block and a 9 degree freedom block. I wish to send the data from the edison connected to this sensor to the other edison through Bluetooth. Is there any way to this.
All the information provided by you’ll will be very helpful to me.
Thanks.
