BLUETOOTH CONNECTIVITY
I want to rad only one NMEA sentance from GPS(GNGGA). So I disable all other messages using comport and read the messages correctly using comport. But when I am trying to read the data over bluetooth, all sentances are enabled. But I want only GGA sentance. And also can’t configure the NM EA messages over bluetooth connection using u-centre.
I’m not sure if there’s a way to disable that on the transmitting side…but it’s likely possible to parse out the GGA sentence with a customer script and pass that to a 2nd API?
