BME280/BMP280 no Humidity
Using an Adafruit BMP280 and the Sparkfun Library (much better than Ada’s) and it shows everything except Humidity.
Temp and Altitude seem to be about right and have no way to verify Barometric, so assume it is OK too, but the Humidity is always zero.
The Ada Library doesn’t even have a Humidity read function. Had I known that I’d never have bought this thing from them. :oops:
Can Humidity be made to work with the BMP?
Thank you.
OK, just found that it doesn’t have a Humidity sensor, the BME280 does. Misleading Amazon descriptions strike again.
