I bought the Sparkfun BME280 breakout board as I am building a wifi weather station.
Anyway, I installed the Sparkfun library for it into the Arduino IDE and then I ran example sketches.
The problem is the temperature is reading 2 to 3 degrees Celcius higher than the ambient temperature as measured by an accurate thermometer. The reading is not stable from day to day so an offset in the code won’t work.
