I have only 1.2VDC available at the input. Is this above the threshold?
If I recall correctly, these don’t work below about 1.8V ![]()
Any alternatives you’re aware of?
Unfortunately no. You’d need something to boost your input up a bit first. Op-amps or transistors might do the trick for you.
