Hi there,
I’ve made an bootloader for the LPC1788 based on KEIL TCPnet stack and FlashFS (fat library)
with this bootloader I can update my application code and program settings like IP Address etc.
I can also jump from the application back to my bootloader to use the “update” mode.
One of my priorities is stability. for example, when my programmed application crashes, I want it to count the crashes (maybe different types of crashes) and decide to reflash the application code with an previous working version from a SDCard.
So what I want is a: Self recovering bootloader
Does something like this exist? I can’t find anything like this.
Does somebody have an idea on how to make this work?
I’ve thought about saving some counting in the flash (it will work, but you don’t want this, programming the flash to much)
Maybe some communication to a FPGA watchdog, but then it’s outside the ARM.
Wouter
