BR-SC30A Spec Software !!!
I was looking through the blueradios website and apparently they have software for this module !!!
i was just wondering how i could aquire this software instead of configuring the module via
thank you
I’ve never seen or used this software. We’ve only used the AT command set.
I’ve sent an email to Blueradios. I’ll let you know what they say - but I’m doubtful. They are usually pretty protective of their stuff.
-Nathan
sparky:
-Nathan
thank you for your responce. yes they do have this software i emailed them about it. according to my conversation with them they said the person i orderd the module from should have copy !! so hopefully they send you one.
Any update on making the BlueWindow software available to SFE customers? It would be very helpful to have this. Using AT commands is very tedious and error prone.
Alternatively, you could use some RS-232 serial port software like docklight (http://www.docklight.de/). All you have to do is save the serial commands you want to send to your bluestamp and you can configure it in a couple of button presses. Just make sure you hook up the Bluestamp to your PC through a MAX-3222 chip (or something like that) or you’ll be unhappy…
