can anyone tell me or point to instruction on how to use the Eagle files (.brd and .sch) available fro so many Sparkfun products? New to using Eagle and i don’t quite see how to add them to a library…
thanks.
thanks.
Adding a schematic or a board file to a library doesn’t make any sense.
So when “Eagle Files” are available for products (I.e. http://dlnmh9ip6v2uc.cloudfront.net/dat … ni-v12.zip) how do I use them?
You simply open them with Eagle. You can then view or print the schematic and generate Gerbers and a drill file from the board file so that you can get your own PCB made.
