I’m a big fan of the MicroMod platform. Would it make sense to have a breakout pin for the EN signal of the voltage regulator? I want to control the voltage regulator with an on/off switch and controller circuit, which will be connected to the pin on the processor (3.3V_EN). My suggestion is:
add a breakout pin for EN signal (voltage regulator enable pin)
add a breakout pin for 3.3V_EN (processor board pin)
In other words, convert the “Voltage Regulator Enable/VE” jumper to a two pin breakout.
Is there any other way to make this work with the current layout?
