Broken GM862 Unit?
Last week I purchased a GM862 unit. For some reason, it won’t start.
pwrmon is always off
status is always off
I tried to boot it with typing on/off to ground for a few seconds but no joy.
I hooked it up to ftdi → hyperterminal, all I got was loopback (even though I didn’t connect tx/rx together).
I’ve tried various power sources, 5V wall adapter through 3.8v regulator (lm317t). I’ve also tried direct from a brand new 3.7V polymer lithium battery.
Does anyone with more experience recommend any other thing to test before I return it for a new one?
I use GM862 nad all works fine. see detail
http://akb77.com/g/gps/handmake-gsm-gps-tracker/
Thanks for the response.
What exactly does the link show? I was hoping for some troubleshooting tips or such. I don’t see how your code helps me. Thanks never the less.
I noticed this on mine, while its powered back the serial actually loops back! Kinda crazy…
Alas mine sstill doesn’t work … it powers on and registers and the GPS serial works fine but the GSM serial is just broken.
