Building a real time system using a F9r and connecting to a ntrip source
I am in the process of building a system using a f9r receiver and eventually outputting a realtime corrected solution to an external device (AVL) via a serial connection. I have a NMEA message being output now from the f9r to my serial device. Now I want to integrate the necessary components to receive the ntrip correction source via a cellular connection. Does anyone have advice on the components i need to add to the f9r to achieve this and how to make the proper connections?. I want to make this system as simple as possible. My eventual goal is to deploy this on a fleet of vehicles.
The F9R guide has a section for connecting to a correction source (it contains links to other guides, the F9R works similarly)…simply get your credentials like so GPS-RTK Hookup Guide - SparkFun Learn and you should be on your way!
Thanks!!! Ill check that out…
