I would like to build a heart rate monitor in a wrist silicon bracelet. Do you guys have any suggestion on which PIC would do the job. I also need BT module and possibility to charge via USB (this is optional).
Just want to hear your feedback. Where should I be cautious, where to pay attention. I am building my first gadget, please do not kill my enthusiasm
@ the OP: I’m not sure where you can find a BT board small enough to mount into one of the above bracelets. Personally I"d be looking for an integrated MCU&BT module that can sample one analog channel. Is it your intention to use an IC meant for the monitoring job, something like what’s used in … ?
I don’t know what kind of detailed data you’re looking for, but if it’s simple heart rate perhaps a BLE solution might work. They are intended to send short packets of data intermittently.
To make the circuitry fit around a wrist, I’ll opine you’re looking at several “boards” connected via flex print. Not the stuff usually done by beginners (it’s $$$s).
