Hi, I have an issue with my new Bus Pirate v3.6a - the USB device is not recognized. Seems like the FTDI chip is failing. I have other FTDI devices that work fine. Things I tried:
- Different USB cables that work correctly with other devices
- Different USB ports
- Connecting directly or through a powered USB hub
- Win10, Win7, Linux
- Different machines
- Older FTDI drivers
Anything else i could try?
Windows says that the USB device malfunctioned, unknown device. From Linux, I get the following in dmesg:
[ 1047.129230] usb 4-1: new full-speed USB device number 6 using uhci_hcd
[ 1047.265233] usb 4-1: device descriptor read/64, error -71
[ 1047.509224] usb 4-1: device descriptor read/64, error -71
[ 1047.745194] usb 4-1: new full-speed USB device number 7 using uhci_hcd
[ 1047.881227] usb 4-1: device descriptor read/64, error -71
[ 1048.125230] usb 4-1: device descriptor read/64, error -71
[ 1048.233224] usb usb4-port1: attempt power cycle
[ 1048.677172] usb 4-1: new full-speed USB device number 8 using uhci_hcd
[ 1049.097113] usb 4-1: device not accepting address 8, error -71
[ 1049.225181] usb 4-1: new full-speed USB device number 9 using uhci_hcd
[ 1049.641229] usb 4-1: device not accepting address 9, error -71
[ 1049.641296] usb usb4-port1: unable to enumerate USB device
I totally forgot to put the link in, sorry about that! (I have a case of Friday-itis!)
Since you bought from a distributor of ours we can’t issue a RMA but if you contact the distributor and let them know we authorize a replacement they will take care of you. If they need any proof, just link them to this forum post and that will be enough.
