Can a single 12V inverter supply power to two EL Escudo Dos boards?
I have an application that requires two EL Escudo Dos boards - running on top of two Leonardo boards. I would like to use the same 12v inverter to feed the AC signal into both boards by splitting the 2 leads coming from the inverter. Will doing this cause a problem for the EL Escudo Dos boards?
It doesn’t appear that this will cause issues. However, you’ll need to double-check the power ratings to make sure too much current isn’t drawn. Make sure to thoroughly test before using in a final application.
