CAN-bus shield supports CANopen?
Link: https://www.sparkfun.com/products/13262
Part SKU: DEV-13262
Just curious if that CANbus shield offered works only w/CAN or also supports CANopen.
I looked through the doc’s and didn’t find anything.
If not, has anyone had experience using CANopen on the Arduino?
  • Chris
Hi Chris.
While we haven’t tried, I don’t see any obvious reasons why the CAN Bus Shield wouldn’t support CANopen. The shield takes care of the physical layer leaving you free to implement you’re own protocol. It’s possible the library might not play nice with CANopen and if that’s the case, you might need to modify the library but the hardware should be OK.
