Can I get 24V@3A out of a USB PD connection?
I’d like to get 24V@3A out of a USB PD connection. I’d prefer a USB C female connection but I’m not too picky, I’ll even take unterminated. . Do you have any board or combination of boards that will do this?
Thanks so much
Joe
USB PD only goes up to 20 volts.
Yes, I know I’ll need a boost as the last stage. The point is, what do I need as the first stage?
You’d need one of these on the input.
https://www.sparkfun.com/products/15801
You will need to configure it to output 20 volts at 4 to 5 amps.
