Can Pan Tilt kit ROB-14391 work with Arduino instead of Raspberry Pi Zero?
Doesn’t seem to be much documentation on the product page for the ROB-14391 Pan Tilt kit but wondering if it can be used with an Arduino instead. I am a noob but just seems to be signal, V, and Gnd on each servo. But doesn’t say what voltage to give it…
Hello rfii!
The pan tilt kit uses standard servos that are rated for 4.8 volts but they work just fine at 5 volts.
You can drive them with an Arduino just like any other servo.
