I have a small project in mind (ROM upgrade for ancient computers) which requires retro-fitting newer Flash Roms into older (and generally no longer existant) ROM caddies for computers like the Tandy Model 100/102/200 and others. The easiest way to do this is to set a bank of vias, then shear thru the middle of the vias, leaving the barrels as the contact to the older “caddy” contacts/pins.
With your service, is this possible?
Roger “Merch” Merchberger
