Using a Sparkfun Postcard with Portability shield. I cannot access the terminal configuration menu when I connect to a terminal program (tera term). When i connect to the board and “press any button” to get into the menu it doesnt pop open the menu, it just resets power on the board or reboots the software.
I figured it out. Turns out that Tera Term isnt the greatest terminal to use in this application. I switched to RealTerm and it worked. Thanks for your reply sparky.
