can't change address on SparkFun Qwiic Single Relay
I tried using example 6 from the SparkFun_Qwiic_Relay.h library.
to change the address from the default 0x18 to a new value (e.g., 0x09);
The code reports that the address has been changed in the serial monitor
But when I run a I2C after, its still the 0x18.
I tried both an ESP32 and a Arduino, no luck.
I ended up using the example from this old hookup guide - it worked
https://media.digikey.com/pdf/Data%20Sh … de_Web.pdf
