viskr
1
Looks like it should all work but I can’t connect
On the BlueSmirf side I can send AT commands, but connect as slave requests return OK then nothing else. The green led is flashing
On the PC running BlueSoleil It identifies the Sparkfun-BT
but it won’t connect ( get connection failed)
they are about 4ft apart
any clues?
Jay_C
2
Did you reconfigure the BlueSMiRF with anything other than the standard settings? Did you change/set a PIN?
Jay
viskr
3
No configuration was changed
After I verified the USB bluetooth dongle on a couple other devices, tech support was contacted, and a repaired/replaced unit is on its way
thanks for the feedback
