vever
February 12, 2014, 3:36pm
1
Hello.
I’m encountering issues on my board, with a kinetis k60. My script works, I could program the flash memory.
But I interrupted the flash programming (by error) before the end, and now the JTAG can"t connect to the board.
I have theses messages :
Error: JTAG-DP STICKY ERROR
Error: MEM_AP_CSW 0x23000012, MEM_AP_TAR 0xe000ed00
I can’t program flash, I can’t halt the board, etc.
I’m wondering if a “mass erase” could solve my problem, but I don’t know how to write on registers with openocd and a “broken jtag”.
If someone have a idea on this problem…
Thanks !
vever
February 13, 2014, 11:20am
2
I solved my problem alone.
Mass erase should be done by openocd at init, but it couldnt because SRST was not configured.
I added “reset_config trst_and_srst”, push reset button on board several times and it worked…
(and sorry, I can’t explain it better … )
I also use the K60 and I have the same error as you. But I can not seem to resolve the error. :?
Can you send me your script so that I comparre with mine?
thank you.
Best Regards.
sg479
November 11, 2014, 8:05pm
4
I am trying to create a manufacturing process whereby our CM uses an Olimex arm-usb-odc-h and openocd 0.80 (or any other linux tool) and programs a Kietis K60 (MK60DX256VMD10). You stated you were able to do this. Would you share your script that accomplished this?
