I’m using Olimex ARM-USB-TINY with an Olimex LPC-2138 board. Fresh install, no other instances of eclipse on the computer.
The first time I try to run the sample project i’m getting this errors:
Open On-Chip Debugger 1.0 (2008-10-04-10:00) svn:exported
$URL: http://svn.berlios.de/svnroot/repos/openocd/trunk/src/openocd.c $
Info: options.c:50 configuration_output_handler(): jtag_speed: 3, 3
Info: options.c:50 configuration_output_handler(): Open On-Chip Debugger 1.0 (2008-10-04-10:00) svn:exported
Error: jtag.c:1351 jtag_examine_chain(): JTAG communication failure, check connection, JTAG interface, target power etc.
Error: jtag.c:1556 jtag_init_inner(): trying to validate configured JTAG chain anyway...
Error: jtag.c:1444 jtag_validate_chain(): Error validating JTAG scan chain, IR mismatch, scan returned 0x3f
Error: jtag.c:1565 jtag_init_inner(): Could not validate JTAG chain, exit
second try:
Error: ft2232.c:1419 ft2232_init_ftd2xx(): unable to open ftdi device: 2
Error: ft2232.c:1434 ft2232_init_ftd2xx(): ListDevices: 2
Error: ft2232.c:1436 ft2232_init_ftd2xx(): 0: Olimex OpenOCD JTAG TINY B
Error: ft2232.c:1436 ft2232_init_ftd2xx(): 1: x¤
this is my config file:
#daemon configuration
telnet_port 4444
gdb_port 3333
#interface
interface ft2232
ft2232_device_desc "Olimex OpenOCD JTAG TINY A"
ft2232_layout "olimex-jtag"
ft2232_vid_pid 0x15BA 0x0004
jtag_speed 3
#use combined on interfaces or targets that can't set TRST/SRST separately
reset_config trst_and_srst separate
#jtag scan chain
#format L IRC IRCM IDCODE (Length, IR Capture, IR Capture Mask, IDCODE)
jtag_device 4 0x1 0xf 0xe
#target configuration
daemon_startup reset
#target <type> <startup mode>
#target arm7tdmi <reset mode> <chainpos> <endianness> <variant>
target arm7tdmi little run_and_halt 0 arm7tdmi-s_r4
run_and_halt_time 0 30
#target_script 0 reset oocd_flash2138.script
working_area 0 0x40000000 0x40000 nobackup
#flash configuration
flash bank lpc2000 0x0 0x40000 0 0 0 lpc2000_v2 12000 calc_checksum
# For more information about the configuration files, take a look at:
# http://openfacts.berlios.de/index-en.phtml?title=Open+On-Chip+Debugger
Can anyone help? I did a google search after these errors and all i got was a page in German ![]()
LE: i did another fresh install on my laptop and i get the same errors
