Can't find openocd.cfg
abhinav:
first let me tell u how much i appreciate all the pains taken by you to write reply for what all i asked.you must have been working with micro controllers for a long time.
1000 small steps will get you there :lol:
abhinav:
but any ideas how i can understand all the confusing lines of code and programs in gdb?
Well text based gdb is not the most userfriendly program out there…
that is why a lot of persons are using frontends like ddd or eclipse,
and to be honest maybe 70-95% are using a frontend.
abhinav:
you must have read many books and links when u were a beginner.
I still read a lot and google a lot and read a couple of other forums like http://stackoverflow.com/ (it’s good if you filter all the C#/.net stuff) etc etc
abhinav:
can u point me in the right direction so that i can understand atleast an error msg …
Well continue to try, and try and try again (even if you feel feel like giving up sometimes)
And don’t forget that you have choosen to start with a advanced piece of hardware :roll: (there are easier mcu:s out there, like the AVR:s)
But the Cortex-M3 is cool… 8)
jsiei97:
abhinav:
So let’s use Insight instead (another gdb frontend) :idea:
Compile info can be found at the bottom of this page:
http://www.fun-tech.se/stm32/gcc/index.php
And example can be found at the bottom of this page:
http://www.fun-tech.se/stm32/OpenOCD/gdb.php
I think you will have better luck with that one 8)
BR
Johan
jsiei97:
Next step…? Don’t know.
Probably try to understand what those link scripts
Compile Olimex blinky
http://fun-tech.se/stm32/gcc/compile_blinky.php
Dissect blinky
http://fun-tech.se/stm32/OlimexBlinky/index.php
Next step…?
How about a internal print buffert that you can read with gdb,
and later get Virtual COM port to work as well…
/Johan
hi thanks i am reading through all the links you posted
hi i think i have loaded a hello world program successfully into the board using eclipse in windows system.any idea how i can see the print out put from the board on my comp in linux?
abhinav:
Sure how about a “usb virtual com port”
There is some code linked from this page
http://www.st.com/mcu/modules.php?name= … B#Firmware
It is called STM32_USB-FS-Device_Lib.
That is my idea (have not had time to look at it thou). :roll:
BR
Johan
k for now,i need your help in a different situation.i have a display lcd from EA DOGM162L-A whose data sheet can be found at
http://nl.mouser.com/ProductDetail/ELEC … yEyQ%3d%3d
(in the documents tab).
i have to get the display to show hello world and i want to use the SPI interface to do it.so i soldered the display to the board so that i use the SPI2 interface according to page 4 of the display data sheet(3.3V SPI).
following the initialisation sequence in the data sheet,i understood i have to first write the data 55H into the display ram so that i can get the display to start.
also i have downloaded the stm32 standard peripheral library from stm site from
so my present trouble is
1)how do i get the spi2 driver installed from the library i downloaded(is it necessary to install at all?)
2)once i resolve the SPI issue how can i proceed to write data 55H to display ram so that my display can come to life
3)this is the final objective, how do i get the hello world printed on the display?
i know this may not be what you are working on right now, but i thought you must have some idea about initializing new interface from your experience.please help
abhinav:
Since we have walked quite far away from the first question,
I think you should create a new one under “Everything ARM and LPC” section.
And in that question only focus on the display problem.
abhinav:
The process is more like:
  1. Download
  2. unpack
  3. build in those files you need in your normal code.
So it is kind of a install, but not a normal one :wink:
I’m actually plan to looking at this part
(but I don’t have that much time right now so…)
BR
Johan
k i have started a new thread at
viewtopic.php?p=84636#84636
k after unzipping,i found .c files for various interfaces including spi.then how do i build it?there is no make file or anything with it.
also once i get it done how do i write data to display ram?
u can answer in the new thread
