When I try to load a new sketch to an ESP8266 Thing via the SF FTDI , I get the message “esptool.FatalError: Failed to connect to ESP8266: Timed out waiting for packet header:”. I get this with the two Things I have tried, and I have experimented with different baud rates without success. Any suggestions will be appreciated. I can send the complete error dump if necessary.
Thank you.
R
Did you follow the steps in the hook-up guide programming steps ? https://learn.sparkfun.com/tutorials/es … -the-thing.
Paul: I’m embarrassed to say I assumed power was supplied through the FTDI. When I reviewed the tutorial, I saw I needed “Thing” plugged in too. Works on the programs I have tried so far.
Cool !!! Great it works now. Often the “devil is in the details”. Trust me that you are not the first to find out and me neither…
