I want to use each of the 3 touch pads on the board simultaneously. At the moment only one pad can be detected at a time. If you press two pads only one will show as touched.
Nayland
Nayland
Looks like the board supports multiple touch but the library doesn’t. Might try searching for an alternative library to see it one might support multiple touch.
