capacitor question
How can I check a SM capacitor that attached to a PCB. I have searched to no luck for the numbers on the capacitor which are 100-6 on the top line and T7 on the bottom line with the number 2 circled and a line above it. This is a missing link to incorporate 3 separate boards into one and have a batch made up.
question answered, Thanks guys
How about you give a summary of what you found out so in the future if someone has a similar issue they might be able to get an answer from your post.
-Bill
Had a friend come over who is taking electrical engineering right now and he tested it with a multi meter set to check uF and it showed 105.1 uF. He said since it was such a low voltage moving through (±2volt) and it had another compacitor right after it a two layer would suffice.
