I am using the LN2410SBC board from littlechips.com. I am using OpenOCD version 86 with the JTAG cable (similar to triton type) provided by littlechips.
I am able to read/write to SDRAM from the openocd prompt. So, JTAG works.
I am now trying to do read/writes to flash, and I get these messages in openocd log:
Error: cfi.c:1203 cfi_info(): cfi primary command set 2 unsupported
Error: cfi.c:422 cfi_erase(): cfi primary command set 2 unsupported
Error: cfi.c:982 cfi_probe(): cfi primary command set 2 unsupported
Error: cfi.c:1147 cfi_protect_check(): cfi primary command set 2 unsupported
The flash is 2 MB Spansion from AMD/Fujitsu (Am29LV160D):
http://www.littlechips.com/downloads/cu … 2358b5.pdf
Appreciate any help,
SK
