I need a prismatic li-po battery pack running at 7.4V (1C discharge) and am considering either a 2S or 2S2P configuration.
Is it possible to wire up 4 individually protected cells in 2S2P or do I need to use unprotected cells and a single protection circuit?
Same question for a 2S wiring, can I use individual protection? If so, what would the wiring diagram look like?
Thanks for any light you can shed on this problem.
