Been getting a lot of use out of OpenAI’s ChatGPT, called Assistant. If you have technical questions, try asking it. I’ve found it either gives me the correct answer or sets me in the right direction every time. It’s like an instant Stack Overflow. If the answer it gives is not specific enough, tell it, and it will clarify.
I’ll be sure to check it out - thanks for sharing!
