i have been using XBEE series 2 modules for transmitting event based 2 bytes of data. I think thats an overkill. I want to know whether a cheaper replacement ( 433 X’ciever???) is available?
Are they simple to interface to a microcontroller?
nRF24L01+ are little cheaper in small batches and lot cheaper in bulk. Optionally for raw data transmission normal 434 RF transmitter/receivers may do you at a few dollars a pop. Both sold in SF shop and easy to implement (434 being the easiest just plug and go)
At $5 or so, no, they're not easy, due to protocols.H.S.Srinivas:
If you can pack into 8 bits, the HT 640 encoder/decoder chips might work
http://www.rentron.com/rf_remote_control.htm
http://www.rentron.com/PicBasic/8-BIT-RF2.GIF
But these are unidirectional, no error detection. If that fits the need.
