Circuit 5A Motor Basics
I am working through this circuit from the Inventors Kit 4.1.2. Using the code below, directly from the SIK Master Library.
When I enter a forward command (f 100) only pins A01 and A02 send a signal to the motors. B02 and B01 remain silent. However, when I enter a backwards command (b 100) both motors receive signals from the two sets of output pins.
I have tried switching motors, switching to a different motor driver, switching the +/- signs on the code, also the polarity of the motors… it all comes to pins B02 and B01 only generating a positive voltage difference.
Suggestions? Any advice appreciated.
SparkFun Inventor’s Kit
Circuit 5B - Remote Control Robot
Control a two wheeled robot by sending direction commands through the serial monitor.
This sketch was adapted from one of the activities in the SparkFun Guide to Arduino.
Check out the rest of the book at
https://www.sparkfun.com/products/14326
This sketch was written by SparkFun Electronics, with lots of help from the Arduino community.
This code is completely free for any use.
View circuit diagram and instructions at: https://learn.sparkfun.com/tutorials/sp … uide—v41
Download drawings and code at: https://github.com/sparkfun/SIK-Guide-Code
//the right motor will be controlled by the motor A pins on the motor driver
const int AIN1 = 13; //control pin 1 on the motor driver for the right motor
const int AIN2 = 12; //control pin 2 on the motor driver for the right motor
const int PWMA = 11; //speed control pin on the motor driver for the right motor
//the left motor will be controlled by the motor B pins on the motor driver
const int PWMB = 10; //speed control pin on the motor driver for the left motor
const int BIN2 = 9; //control pin 2 on the motor driver for the left motor
const int BIN1 = 8; //control pin 1 on the motor driver for the left motor
int switchPin = 7; //switch to turn the robot on and off
const int driveTime = 20; //this is the number of milliseconds that it takes the robot to drive 1 inch
//it is set so that if you tell the robot to drive forward 25 units, the robot drives about 25 inches
const int turnTime = 8; //this is the number of milliseconds that it takes to turn the robot 1 degree
//it is set so that if you tell the robot to turn right 90 units, the robot turns about 90 degrees
//Note: these numbers will vary a little bit based on how you mount your motors, the friction of the
//surface that your driving on, and fluctuations in the power to the motors.
//You can change the driveTime and turnTime to make them more accurate
String botDirection; //the direction that the robot will drive in (this change which direction the two motors spin in)
String distance; //the distance to travel in each direction
void setup()
pinMode(switchPin, INPUT_PULLUP); //set this as a pullup to sense whether the switch is flipped
//set the motor control pins as outputs
pinMode(AIN1, OUTPUT);
pinMode(AIN2, OUTPUT);
pinMode(PWMA, OUTPUT);
pinMode(BIN1, OUTPUT);
pinMode(BIN2, OUTPUT);
pinMode(PWMB, OUTPUT);
Serial.begin(9600); //begin serial communication with the computer
//prompt the user to enter a command
Serial.println(“Enter a direction followed by a distance.”);
Serial.println(“f = forward, b = backward, r = turn right, l = turn left”);
Serial.println(“Example command: f 50”);
void loop()
if (digitalRead(7) == LOW)
{ //if the switch is in the ON position
if (Serial.available() > 0) //if the user has sent a command to the RedBoard
botDirection = Serial.readStringUntil(’ '); //read the characters in the command until you reach the first space
distance = Serial.readStringUntil(’ '); //read the characters in the command until you reach the second space
//print the command that was just received in the serial monitor
Serial.print(botDirection);
Serial.print(" ");
Serial.println(distance.toInt());
if (botDirection == “f”) //if the entered direction is forward
rightMotor(200); //drive the right wheel forward
leftMotor(200); //drive the left wheel forward
delay(driveTime * distance.toInt()); //drive the motors long enough travel the entered distance
rightMotor(0); //turn the right motor off
leftMotor(0); //turn the left motor off
else if (botDirection == “b”) //if the entered direction is backward
rightMotor(-200); //drive the right wheel forward
leftMotor(-200); //drive the left wheel forward
else if (botDirection == “r”) //if the entered direction is right
leftMotor(255); //drive the left wheel forward
delay(turnTime * distance.toInt()); //drive the motors long enough turn the entered distance
else if (botDirection == “l”) //if the entered direction is left
rightMotor(255); //drive the right wheel forward
else
void rightMotor(int motorSpeed) //function for driving the right motor
if (motorSpeed > 0) //if the motor should drive forward (positive speed)
digitalWrite(AIN1, HIGH); //set pin 1 to high
digitalWrite(AIN2, LOW); //set pin 2 to low
else if (motorSpeed < 0) //if the motor should drive backward (negative speed)
digitalWrite(AIN1, LOW); //set pin 1 to low
digitalWrite(AIN2, HIGH); //set pin 2 to high
else //if the motor should stop
analogWrite(PWMA, abs(motorSpeed)); //now that the motor direction is set, drive it at the entered speed
void leftMotor(int motorSpeed) //function for driving the left motor
digitalWrite(BIN1, HIGH); //set pin 1 to high
digitalWrite(BIN2, LOW); //set pin 2 to low
digitalWrite(BIN1, LOW); //set pin 1 to low
digitalWrite(BIN2, HIGH); //set pin 2 to high
analogWrite(PWMB, abs(motorSpeed)); //now that the motor direction is set, drive it at the entered speed
Double and triple check the wiring/soldering, this is usually a case of having a bad solder joint or loose wire
I re-created the entire circuit with a whole new set of equipment, and I got the same results. I’m also scratching my head because if it were a connection problem I wouldn’t be getting a voltage readout on those pins for the + voltage signal either- but I do. It’s the negative voltage that’s not coming through on those specific pins.
Open to suggestions/next steps.
If you’ve ruled out the wiring, driver, and motors…the only left is the code
Try starting over from scratch and see if the default example works
