first off i love messing around with this stuff even though i know next to nothing about resistors,capacitors and stuff. I love trying to fix stuff. Our power went out, hooked up the generator and didnt realize it was on 240 volts. I got it switched in around 5 minutes. Lucky i only lost this food saver vac sealer and a LED bulb and two surge protectors. The food saver was off but it was making a noise like the motor was running slowly and smelled like an electrical issue of course. I looked the board over and the only thing i found was— see the attached photo . since the board had C3 next to this thing im guessing its a capacitor. There are two of these, the other appears to be ok. Should i replace both ? Could anyone tell me what to order to replace this. It’d be interesting to hear what happened to. Bet ill never forget to switch the power lever again !!!
GlennRowe:
My only advice is to call them up. They are really great to work with, mine has been going for 4+ years strong, my dad had one for 5+ years , upgraded it crapped out in 6 months he called and they gave him all sorts of discounts and bags etc because of it.
I think you’ll be lucky if that’s the only thing broken. Here’s a replacement: https://www.digikey.com/product-detail/ … 4-ND/56468
There is probably more damage than just a burned capacitor.
It maybe in a power line derived supply. Where a capacitor is used to limit the current in to the supply. With a few diodes, maybe a low value resistor, small coil and filter capacitors. I would check sealer for things like shorted or open diodes and damage filter capacitors. Before just replacing the blown capacitor in your photo.
