We are looking for help with some simple circuit designs.
It would be super if we could get this done with lightweight components… ( i.e.,
no microcontroller )… instead use a 555 timer chip… or some other chip/ components/ method…?
For example… light up a series of LEDs one at a time… and produce other effects using a series of LEDs… like a wave effect, or light up in a wave and then flash, etc…
Also, we need the LEDs to light up at various time intervals… that can be adjusted to any time interval ( using a potentiometer to adjust the current/volts ) … e.g., one LED each ( 1 second, min, hr, day, week)… etc…
Thanks for your help!!
Please send any questions to [ thomas g account AT gggggmail DOT com )
You should be able to do this with some simple logic chips.
Check the 4017 decade counter chip to start, that plus a bit of other glue logic and a 555 should be able to create the effect you’re looking for.
Forrest Mims had some books with circuits that did this sort of thing, you might check those.
http://www.forrestmims.com/
Circuit designs can easily be done using EDA software. I would propose you first choose the EDA software of your choice then have a good knowledge on the electronic components and signal processing. With that you can easily design this circuit by yourself by just playing around with the EDA software components. i suggest you download Proteus or KiCAD EDA to help you out.
see the links for EDA and simple circuit example for a start;
https://www.labcenter.com/downloads/
https://www.bing.com/search?q=kicad+dow … 01&PC=U531
https://www.instructables.com/Simple-Ba … -Use-LEDs/
