Hi guys,
Ok, I admit it - i’m an artist not an electonics expert! I’m looking for some advice on a new project I’m making - its basically a group of parallel wired LEDs in the form of domino pieces, running off a usb powered either wall plug converter/ battery bank via a resistor to drop from 5v to 3v ish. The circuit would be very easy to just solder into a standard board, but i have access to a CNC milling machine and so would like to create a nice design for the pcb leaving as much copper on the board as possible as it looks so cool!
So my question is, do you know of a software i can use to get this sort of look (it would need to be quite a flexible software i think) and do you have any other tips for me?!
Thanks guys
Eric
