This panel will also be black solder mask with white silk screen. I think I figured out how to change the silkscreen color…
But do I need to do anything to change the solder mask color to black?
Don’t know about the board shapes, but the silkscreen colour and soldermask colour are not specified in the software, just tell Sparkfun when you order the full panel what colour silkscreen you want…
We panelize the designs as submitted to us by the user. If you need a routed design (half moon is no problem) be sure that your border reflects this. If you have a rectangular border (as in your picture) you’ll get a rectangular board.
We offer white silkscreen and green solder mask. You can ask for something else but without a full panel order, we can’t help you
Routing them apart will get you individual PCBs. If you need a v-scored panel (as in the tutorial) you cannot do anything but rectangular shapes.
There are other ways to do panels of odd ball shaped PCBs. This is called ‘mouse bites’ but I’ve never done it and I’ve never found out from GP PCB what it takes to get this done.
All our rounded boards have to be stenciled indiv. All our square boards are done in batches. Just depends on what you are doing and how long you want to take stenciling. Stenciling a 3’x4’ panel would be impossible to line up correctly. Stenciling a .3x.3" board indiv. would take forever and a day.
where the *'s are routing
and the --- is a vscore line between the two boards.
IE have the half moon PCB1 inverted and routed out
followed by PCB2 in regular oreintation and routed out.
and only vscore the middle (not routed).
That way I'd be able the stensl two PCBs at once. "bake them"... and then snap them apart after assembly.
Find somwehere with a laser cutter. Our one at work does quite well cutting PCB material cleanly…
sparky:
Laser cutter! What a fun idea. What about the gases from vaporized copper and FR4? Can the laser cut through ground pours?
-Nathan
Our one is a bit old and clunky, and hasn’t got the power to cut through copper, so you have to etch the board clear where you want to cut it. It uses an extraction fan to remove nasty gases.
Weactually use it for very quick prototyping of pcbs too, just cover the whole board with resist, and laser off the resist where you want to etch, tuns out quite nicely…
